Layup Question
Ohio Bob
Re: Layup Question
Unread post by Ohio Bob »
Obviously this isn't a fair comparison in scope and size, but laying up even a pleasure boat takes some time and a thorough checklist to make certain you do not forget anything. Sea strainers, check valves, water systems, waste systems, batteries, engines, generators, etc. With watch crews and keepers onboard, are any systems typically kept live during layup in limited fashions? Water/waste, heat, etc.
Guest2
Re: Layup Question
Unread post by Guest2 »
Deck dept 1-3 days, usually 2. Engine Room 5-10 days, depending on winter work planned. Steamers Deck dept 1-3 days. Engine Room 10-15 days
That's what I remember from my sailing days on the lakes (20 years ago). I think the Middletown layup was 18 or 19 days. Columbia Star was 8 or 9 days.
Re: Layup Question
It takes the deck crew just a day or two to have the vessel laid up before they leave. For engine crew it depends on steamer vs diesel and what work is planned. On a steamer it also takes a couple of days to wind things down and idle the plant.
Re: Layup Question
The deck department usually leaves in a day or 2, engineers/conveyorman, galley maybe 5 to 7 days later.
Layup Question
Just a quick couple of question regarding layup. Once at the layup dock how long does it take to get the vessel ready for the winter? Does the crew stay onboard until everything is shut down or do they stagger their departure? Thanks.
