Show here.
https://www.seawaysalties.com/vessel-in ... index.html
Liquilady was launched as Busen Rolllo 4 April 1950 at Greenock by Scotts Shipbuilding & Engineering Co., Ltd., a large motor tanker, for St. Helier Shipowners Ltd., London. Later Jarabella and San Stefano, Porter chartered it 1966-1967 for lake service, it then owned by Pan American Steamship Corporation of Panama Inc., Monrovia, managed by A. N. E. Vanizelos, Athens. 520.3 x 69.4 x 37.1; 11392 gross and 6654 net tons; Doxford 5-cylinder MN1100, 5500-bhp. It arrived at Cartagena 24 November 1968 for conversion to a storage barge and dismantled there by José Navarro Francés, demolition begun in January 1972. Here it is as Busen Rollo (bottom), a René Beauchamp photograph of it as Liquilady, and as an oil transfer barge at Cartegena, 1971 (top).I seem to remember another ship in that fleet called the Liquilady.
Interesting. How did these vessels handle in rough weather? Seems like being that low they wouldn't roll much.Steamboater66 wrote: October 13, 2026, 11:07 pm 2346h EDT Tues. Oct.13/26
In response to OhioBob about freeboard of ‘50’s -60’s vintage lakes tankers…
Tans were built in the centre of the hull to maximize load bearing and in ways when loaded kind of acted like ballast and steadied the ship. The flat deck areas or harbour decks as we called them were often awash when the ships were loaded to maximum. These harbour decks were likely 8-10 feet wide from where they abutted the tank outer sides. The tank sides were 8-10 feet high. The harbour decks were actually used as decks by crew when alongside loading /unloading cargo. Crew could stand on them when coupling hoses to manifolds for loads being pumped out of or into the cargo tanks. To facilitate crew movement fore and aft catwalks with handrails were located in the centre of the hull either above the tank tops or between port and starboard tanks .
