McKee Sons grounding
Re: McKee Sons grounding
As a steamer, she had a pretty full compliment too - 3 wheelsmen, 1 bosun, 3 watchmen, 3 deckwatches, and 3 deckhands. (The forward cabins were very crowded.) Back aft . 2 gatemen, 2 conveyormen, and I believe that the ER had the usual staff of engineers along with 3 oilers and a day wiper. Galley consisted of Steward, 2nd Cook, Porter, & Dishwasher. Living in the after end was Loud due to an extremely noisy turbine, but everybody had their own room, where in the Forward end, there were 3-4 crew per room.
To take advantage of a loophole in U.S. Coast Guard regulations, which essentially dictate that a tug pushing a barge is not required to have as large a crew or be subject to the level of inspection / scrutiny that a 'traditional' ship of the same size and purpose would be. This saves a considerable amount of operational cost of the vessel, especially in the labor department.Guest wrote: So the tug is pretty much just a removable propulsion plant then, with a galley and sleeping quarters?
Why didn't they just update the power plant in the McKee Sons itself?
So the tug is pretty much just a removable propulsion plant then, with a galley and sleeping quarters?Guest wrote:The tug and all navigation and piloting is controlled from the PH of the McKee Sons.
When I crewed aboard the McKeeSons in 74, her Brain Box (Pilot House) was very nicely appointed.
Andy Morrison
Thanks, for this photo I used my Canon G12 compact. It's an awesome little camera.Norskellunge wrote:Nice shot, Andy - if you don't mind my asking, what camera do you use?
Norskellunge
Do they control that boat from the old existing pilot house or the tugs pilot house?
Looks like the view from the tugs pilot house would be very poor to non existent
with the unloading gear sticking up the way it does.
Andy Morrison
The McKee Sons made it's way back to the DTE dock in Trenton this morning. Let's hope it has a more uneventful exit this time.
Bob Chambers
Manuerving a large ship in this area of the Trenton Channel is like threading a needle. Vessel must clear the swing bridge and cribs just north before making a 180 deg turn agianst wind and current before the channel ends with the mud bank.
aarcr
Obviously an expensive problem. Is this something that will likely result in a suspension or firing of the captain or pilot?
Divers did the inspection, the McKee Sons is next bound for Sandusky to load coal again.MichaelB wrote:Will the Coast Guard be doing an inspection at the Edison dock, or will they be doing the inspection elsewhere? Is there a local dry-dock available? And if they are doing the inspection, how will it be done? I can't imagine what it would be like diving into the river with water temps being as cold as they are to inspect the exterior of the hull.
MichaelB
KenB
She loaded the coal in Sandusky, Ohio after coming from Cleveland, Ohio.
The coast guard says she was coming from cleveland.where would she load coal at in cleveland?
Andy Morrison
This is from yesterday. There were a couple kayakers checking them out and a steady stream of onlookers. I'm going to head back there in a bit this morning.
I'm wondering if the McKee Sons (or any other tug-barge combo like the Joe Thompson) has ever delivered coal to this DTE plant before? Also, does anyone know if they had tugs with them at the time of grounding? ASC vessels always use two tugs to make this dock.
Slip
Why are they attempting to pull the barge forward, rather than sideways?
MichaelB
The south end of Grosse Ile can be quite rocky and can be fairly shallow in many areas. I used to sail down there when I was married, and a 6 foot keel was something to worry about if you got off course.Jim B wrote:Having surveyed this area numerous times for the Corps of Engineers, I feel the big problem is the high berm of rock that exists along the downstream edge of the channel. There is only 6 to 8 feet of water (at Low Water Datum) over this rock ridge which prevents the tugs from pushing from the downstream side. These rock berms are found along the edge of all the channels in the lower Detroit River.
As a separate note, the Free Press does have some inaccuracies in the article. It's nice to see some Boatnerd fans and users offering commentaries in the older article and in the article posted today, using information and referencing Boatnerd, to correct some of the data. Kudos to those people.
