Stewart J Cort
CottonwoodStudios
Re: Stewart J Cort
Unread post by CottonwoodStudios »
I guess I never thought of it that way. When I was on, the engine crew used it a lot for whatever they needed done. It would make sense that they'd need something to open the hatches in case the pumps would fail.
Grizzly
Re: Stewart J Cort
Unread post by Grizzly »
Old I beamer wrote:Gee, things must of changed over the years. The USCG required us to have it to remove hatches when the automatic hatches didn't work. We sometime used it to remove thee ballast pumps.
See that is what I heard from the Cort's deck crew. That it was for opening the hatches in case of failure, as well as other uses. Also learned that it was operated and maintained by the engineering side and not deck crew.
Just what I heard when I was on.
Chris M
Re: Stewart J Cort
Unread post by Chris M »
Old I beamer is correct. I was aboard her last yr and asked the same question and was told it was for the cargo hatches when the automatic system didnt work. It has also been used for other misc work but that's the main reason for having it onboard
Old I beamer
Re: Stewart J Cort
Unread post by Old I beamer »
Scott
Re: Stewart J Cort
Unread post by Scott »
Thanks, it kinda looked out of place.
ebs
Re: Stewart J Cort
Unread post by ebs »
to work on topside mounted ballast pump equipment.
Scott
Stewart J Cort
Why is there a crane on the deck of the Cort?
